Yeah, I'm sure he wants that in his pond when it rains and washes it off the boards. Get a nice oil sheen.Treat any wood with diesel and/or used motor oil to make it last longer
The poles are in very good shape so I am considering that after removing the 2x6 boards. Between my tractor and excavator together it should be no problem.If the old bridge is strong enough, you can drag or push the trailer deck across it before you take it out. You could probably do it yourself with your tractor and excavator which then could handle each end to set it.
you have something to lay the trailer across with? Or you going to roll it across the existing, then demo the old to drop the trailer through?
Edit- JaredV posted the same idea as me, he was just faster.
Hell yea! Watched them on tv back in the dayCouple of ramps at each end?![]()
Definitely need a bridge for boat passage and the water is 8-10 ft deep under the bridge.Do you need a bridge ??
How bout 4 or 5 foot OD culverts. Side by side.
Lot of water flow under the bridge ?
and it's deeeaad sexay (Fat b*****d voice)Definitely need a bridge for boat passage and the water is 8-10 ft deep under the bridge.
