Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
What current flows to TVC solenoids on komatsu dash 6 excavator, if the speed sensor is defective and the working mode is H, should it be a constant current like when using G mode? Thanks
The current through the TVC is measured in milliamps and generally isn't something you need to do. The manual will give you an ohm reading range which has always worked for me.
Usually when the speed sensor quits working the computer dials you back to about 50% of pump absorption torque. You can shift the prolux switch which if I remember right would give somewhere around 65 - 70 percent.
Well John, it is easy to teel that the speed sensor is bad, all you have to do is to measure its resistance while engine is stopped, and also you can measure voltage generated from it while engine is rotating
The speed sensor is well known, it is mounted on the flywheel housing.
Actually there is a fault code, that' why i am asking about the consequence on hydraulic speed.
jey_c
I was just asking to make sure I didn't steer you down the wrong path for troubleshooting your machine. I hope you didn't take offense with my question.
Here is an observation I've seen with the Komatsu speed sensor issue. When the speed sensors over heat and burn out from the bell housing being full of oil, the computer doesn't put out a fault code. I figured it was because the sensor is shorted through and the computer would sense a voltage on the ground side. What I have found was when there was a fault code, there was an issue with the wiring harness.
John my friend, i really appreciate the way we do here for troubleshooting and i assure you i like how you try to find out solution when i need some expert help. so no worry at all
