macmoter Italian excavator and self-propelled crawler manufacturer
trombeur
italia
Would anyone have information on "macmoter" earthmoving machinery, an acronym for earth-moving machinery, a small but important Italian manufacturer?
The company founded in 1969, the MACMOTER, with its factory in Modigliana (FC) not far from Bologna, was taken over in 1978 by Mr. A.J. Häringer
and from his company Haba Finanz.
Thanks to the brilliant intuitions of the new management, the company had a remarkable growth that led to the birth of another factory in Silandro, in the province of Bolzano. In the 80s, always looking for a growing improvement, the production cycles of the two plants were equipped with ultramodern assembly lines, welding robots and plasma cutting equipment, which ensure a high capacity and production quality.
this article wants to be a tribute to a great Italian brand that unfortunately leaves us
sin!…
The company's production was as follows:
Backhoes -
3200T
backhoe
Depth of Digging Max 3200mm
Weight: 900 Kg
Mini Excavators - from 1.5 to 5 tons
M1-MINE
360 ° Hydraulic Excavator
Hydraulic Mini Excavator 360 ° from 12 KW / 16 HP
(with compressed air engine)
Weight: 1850 Kg
Made with anti-explosion characteristics for use in underground mines
MINIROPA M1S
Mini Excavator with rubber tracks 13.2 KW / 18 HP Weight: 1500 ÷ 1700 Kg
MINIROPA M2S
Mini excavator with rubber tracks from 18.4 KW / 25 HP
Weight: 2000 ÷ 2200 Kg
MINIROPA M3S
Mini Excavator with rubber tracks from 20 KW / 27CV Weight: 3200 ÷ 3400 Kg
MINIROPA M5S
Mini excavator with 31.5 KW / 42.5 HP rubber and steel tracks
Weight: 4700 ÷ 5000 Kg
Compact blades - from 2 to 2.8 tons
CASTORO 35
Servo-driven compact four-wheel drive shovel
Compact shovel with 32 KW / 43.5 HP
Weight: 2700 2700 ÷ 2800 Kg
CASTOR 45
Weight: 2700 ÷ 2800 Kg
CASTOR 48
Chargers - from 6.3 to 20 tons
L6C
Hydrostatic loader
56 KW / 76 HP Hydrostatic crawler shovel
Weight: 6.35 tons
Bucket Capacity: 0.8m3
LC100
Hydrostatic loader
74 KW / 100 HP Hydrostatic crawler shovel
Weight: 7.4 tons
Bucket capacity: 1.0 m3
LC150
Hydrostatic loader
125 KW / 170 HP Hydrostatic crawler shovel
Weight: 15.9 tons
Bucket capacity: 2.0 m3
Independent and oscillating carriages with hydraulic locking
LC200
Hydrostatic loader
155 KW / 210 HP Hydrostatic crawler shovel
Weight: 20 ton
Bucket capacity: 2.6 m3
Dozer - from 5 to 14.5 tons
D6C
Hydrostatic Dozer
Power: 56 KW / 76 HP
Weight: 5.6 tons
Blade capacity: 1.20m3
DI50M
Hydrological Dozer for port works
60 KW / 81 HP hydrostatic dozer
Weight: 5000 Kg (special version for working in port within merchant ships)
D70M
Hydrostatic Dozer
62 KW / 83 HP hydrostatic dozer
Weight: 7.3 to 7.9 tons
D80M
Hydrostatic Dozer
69 KW / 93 HP hydrostatic dozer
Weight: 8.7 to 9.4 ton
D100M
Hydrostatic Dozer
82 KW / 110 HP hydrostatic dozer
Weight: 9.6 to 10.4 tons
Agricultural Tractors - from 4.8 to 5.1 tons
WTX
Hydro-static Agricultural Tractor
Multi-purpose tractor, chopped, suitable for agricultural, fruit and vegetable and horticulture applications.
Available in 125 to 140 hp versions
Crawler Excavators - from 6 to 10 tons
M6
Crawler Hydraulic Excavator
Tracked Hydraulic Excavator from 41 KW / 55,5 HP
Weight: 6100 ÷ 6500 Kg
M8
Tracked Hydraulic Excavator with 51 KW / 69 HP
Weight: 7500 ÷ 8000 Kg
M10
73,5 KW / 98,5 HP Tracked Hydraulic Excavator
Weight: 9,200 ÷ 9,800 Kg
Wheeled Excavators - from 5 to 11 tons
M6M
Wheeled Hydraulic Excavator
Wheeled Hydraulic Excavator with 41 KW / 56 HP
Weight: 6300 ÷ 6800 Kg
... details
M8M
51 KW / 69 HP Wheeled Hydraulic Excavator
Weight: 7400 ÷ 8000 Kg
... details
M10M
54 KW / 73 HP Wheeled Hydraulic Excavator
Weight: 9200 ÷ 9800 Kg
... details
M12M
74,5 KW / 101 HP Wheeled Hydraulic Excavator
Weight: 10900 ÷ 11500 Kg
All Round Excavators - from 7.6 ton to 8 ton
SX8
All Around Tracked Hydraulic Excavator
47 KW / 64 HP Hydraulic tracked excavator
Weight: 7600 ÷ 8000 Kg
SX8M
"All Around" wheeled hydraulic excavator
47 KW / 64 HP Wheeled Hydraulic Excavator
Prime Mover - from 7 to 15 tons
X150
Multi-tool crawler tractor
Multi-tool crawler tractor for: 145 hp
Weight: 7 tons
175
Track-mounted tractor for multi-tools: 145 ÷ 175 HP
Weight: 7.5 ton
X240
Track-mounted tractor for multi-tools: 280 hp
Weight: 12.0 ÷ 15.0 ton
XL300 TRACKED TRACTOR DOOR MULTI-TOOLS
Track-mounted tractor for multi-tools: 300 hp
Weight: 12.0 to 15.5 tons
Pipelayer - from 22 to 46 tons
PL200
Pipelayer
Pipelayer of 110 KW / 148 HP
Weight: 22,000 Kg
that ...
Pete1961
Shropshire U.K.
Regarding the track loaders, I believe there was once made an LE8 & later an LE9, both of these had engines at the front of the vehicle. Later the LE9 was replaced by the rear engine LC100 I think
Sadly a huge snowfall destroying the factory roof was the final straw for the company. Is there anyone offering parts or rebuilding of the track shovels (as there are men rebuilding old Kamo Machines) ?
I understand the track systems were made by Berco, & that there are spares for both rubber & steel track.
My worry would be sourcing drive motors or variable pumps if these parts failed, I think they would have been a bought in component.
I have never operated a Macmoter loader but heard good things of their build quality, this company was the last maker of a small conventional track loader, apart from the very small & not well made Dongfeng Chinese machines
trombeur
italia
grazie per il cortese intervento e le notizie aggiuntive, se qualche altro amico ha avuto altre notizie o foto o altro materiale informativo, lo invito a scrivere e ad intervenire grazie ancora
trombeur
italia
thank you for your valuable intervention and your additional information, we will certainly treasure it, if you had any other information or photos I invite you to participate in the discussion thanks again
