crane operator
R series Mack with a national boom truck. Truck had rims on it with not enough offset, so it had a horrible turning radius, it does have a fairly long wheelbase that doesn't help. 425 floats up front.
I've installed new front rims with much more offset, and adjusted the axle stops in, so now I have at least some turn.
The problem is that it seems to stop turning at the old axle stop location. If I jack up the front end, it will go from stop to stop. If I'm sitting on the tires, with the weight of the crane on them, it only steers to the "old" angle area, and runs out of power steering. If I'm rolling, I can force it to turn to the axle stops, but it takes a pretty good pull on the wheel.
I'm thinking the pressure reliefs need to be reset in the steering gearboxes. I've never done this, so I'm kind of flying blind, but willing to listen to any old Mack man's advice.
The only other thing that might be happening, is the king pins "rough" or dried up where the "old" setting stopped, making it hard to turn, but I don't think that's the case. I gave them a good greasing, and you can disconnect the pitman arms and push them around.
The Mack has dual steering boxes, and they are the inside the rail style boxes, so access isn't great.
Couple pictures.
I'm assuming the pressure relief pins have to be in each end cap, so that the piston would move each way and "release" the pressure? but it doesn't look like these boxes have any adjuster pins in the end caps.
Couple pictures.
