lug nut size
Discussion in 'Trucks' started by da'yoop, May 12, 2014.
  1. da'yoop
    da'yoop Well-Known Member
    May 19, 2010
    151
    upper michigan
    Anybody have an idea what size socket I'm going to need for the lug nuts on my '89 Ford L9000? It's out in a gravel pit and I don't have much for big tools. I'm going to have to borrow or rent some tools to take out there with me and hope I've got the right one. It's an hour drive one way. I'm guessing it's somewhere around an inch and a half but not sure. :Banghead
  2. 525isx
    525isx Well-Known Member
    Jul 4, 2010
    104
    log trucker
    western wa.
    1 1/2 is budd outer nut size, I believe 13/16 square on the inner lug nut. hub pilot are 33mm (1 5/16 works) 8 stud hub pilot I believe are 1 1/2
    525
  3. da'yoop
    May 19, 2010
    151
    upper michigan
    I probably should have mentioned it's on the front of the truck.
  4. 525isx
    Jul 4, 2010
    104
    log trucker
    western wa.
    1 1/2 budd, 33mm (1 5/16 ) hub piloted
  5. da'yoop
    May 19, 2010
    151
    upper michigan
    Thanks man..........'preciate it. Now the fun starts. The axle is about 6 or 8 inches off the ground and I don't have a big enough floor jack. My plan is to block it up as best I can and then dig a hole under the tire to get it off the truck. I'm sure it's been done many times before. Just makin' due with what I got.
  6. buckfever
    buckfever Senior Member
    Aug 12, 2010
    813
    southwest pa
    Don't forget the left side has left handed threads and the right side has right handed threads.
  7. 525isx
    Jul 4, 2010
    104
    log trucker
    western wa.
    drive it onto a block of wood,to get the jack under it
  8. clintm
    clintm Senior Member
    Jul 7, 2013
    974
    charlotte nc
    y'all forgot it may be dayton wheels it is in michigan
  9. 1466IH
    1466IH Senior Member
    Feb 4, 2014
    608
    prairie du rocher, il
    If they are daytons or spoke wheels it is 1 and a quarter inch. sorry my question mark and back slash key just quit working along with the key for the last letter of the alphabet lol
  10. da'yoop
    May 19, 2010
    151
    upper michigan
    Really? I didn't know that, thanks. It's the drivers side, so left hand threads. Good to know.
  11. da'yoop
    May 19, 2010
    151
    upper michigan
    I didn't want to drive it because the beads broke and I didn't want to damage the tire. Plus my biggest floor jack is only a 3 ton. I guess I could go buy a bottle jack but I'd have to dig a hole to get it under the axle.
  12. da'yoop
    May 19, 2010
    151
    upper michigan
    I don't get it???? I'm just a dumb Yooper :)
  13. 1466IH
    Feb 4, 2014
    608
    if they are spoke wheels they are all right hand and it is always best to vizually check the threads because if the studs have ever been changed they may have been replaced with whatever was on hand. I have personally done this so bring a wire brush along and make sure what thread direction they are
  14. da'yoop
    May 19, 2010
    151
    upper michigan
    Oh ya, will definitely be checking for left or right hand threads. Made that mistake a long time ago on a car and broke off 3 studs before I figured it out (told you I was just a dumb yooper)
  15. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,104
    Mechanic/welder
    Wherever I end up
    Bring 2 12ton bottle jacks start with one under the spring or whatever til you can get the other under the axle beam. you should be good to go then.
  16. da'yoop
    May 19, 2010
    151
    upper michigan
    Good idea there RZ........and my son lives in Medical Lake. He talks about Moses Lake.
  17. 1466IH
    Feb 4, 2014
    608
    If it is a decent tire you arent going to hurt it by driving it carefuly onto some blocks
  18. RZucker
    Jul 7, 2013
    4,104
    Mechanic/welder
    Wherever I end up
    Weve got some good sand dunes and really good bird hunting.
  19. da'yoop
    May 19, 2010
    151
    upper michigan
    Here's a pic.......what kind of wheels are these?
  20. Homemade
    Homemade Member
    May 12, 2014
    10
    Wi
    White ones :)
