Ronsii
- Joined
- Jun 26, 2011
- Messages
- 3,464
- Location
- Western Washington
- Occupation
- s/e Heavy equipment operator
Yep, down here the fuel companies will fill whatever you tell them to fill
I was able to get a hold of 325 gallons of off road diesel from a generator at a hospital last year. Filled my tote and hauled it back. It was illegal to haul for me that much fuel, but State Trooper I talked to said don't pass a weight station, put a tarp over it, and don't get in an accident. Getting off topic
I mentioned it to a fella that fills farm diesel tanks, what I have and he had no issue with it. Now he did not look at my setup, but I told him what I have. Have one tote sitting on another for gravity feed. Buddy uses same tote but uses a pump to pump it out
Now the ball valve may leak (depends on how old) but all have caps to close them off. It there is another leak for simular get some cheap vitron gasket and replace cap gasket
The DOT in NB have been replaced with the public safety enforcement. Basically the old highway patrol. In the last few years they started going after everything. Dot always left our fuel truck alone. We have a 2000 liter tank in a cube van. They saw someone fueling out of the back of it. Had to have placards, the tank had to be inspected, the driver had to have a dangerous goods ticket. Then they checked all the slip tanks. we had mostly old truck tanks in a frame. They all had to be replaced. Then they started picking on our one ton trucks. We have hauled the Bobcat with the asphalt grinder, bucket, 2 brooms, and water tank on a three axle trailer behind a 4 door F450. Now the driver needs a class 3 without air brakes to drive the truck.A lot of pumps say on them to only use approved containers. I think it would totally depend on the cop or DOT that pulled you over. There are a few laws that are a real grey area like caps on cylinders in transport. They sell caps that allow you keep regulators on but they aren't DOT approved. There are a lot of welding trucks with regulators attached to cylinders but I talked to someone who got a $750 fine with the snap caps when the law and enforcement rules aren't real clear. He thinks it was basically a gung ho highway patrol wanting to find something wrong. His cylinders were securely attached and upright. It would have taken a collision with train to cause a problem. Probably more chance of a gas tank exploding. I guess you need to decide if taking the risk is worth it.
Yeah cuttin edge, they started doing that around here few years back... anybody with a one ton and a trailer behind it was getting pulled over!!!The DOT in NB have been replaced with the public safety enforcement. Basically the old highway patrol. In the last few years they started going after everything. Dot always left our fuel truck alone. We have a 2000 liter tank in a cube van. They saw someone fueling out of the back of it. Had to have placards, the tank had to be inspected, the driver had to have a dangerous goods ticket. Then they checked all the slip tanks. we had mostly old truck tanks in a frame. They all had to be replaced. Then they started picking on our one ton trucks. We have hauled the Bobcat with the asphalt grinder, bucket, 2 brooms, and water tank on a three axle trailer behind a 4 door F450. Now the driver needs a class 3 without air brakes to drive the truck.
