k45
Stability is not a published spec per say, but you can pretty much group them into 2 categories: Deere and New Holland, 60% rear/40% front axle wt, and everybody else, 70% rear/30% front. From my experience, the more even distribution and lower center of gravity makes a Deere pretty hard to beat on slopes. A 320 is a 2000# ROC machine w/ 66 hp. You can bump it up another 350# with counterwts, but then you're gonna be butt heavy like a Bobcat.
Another option would be to add solid tires. That gives you a huge amount of extra weight down low without screwing up your balance too bad.
Good information, thanks!
Your comment about rear weights sounds right on. I wonder if they can be mounted in the front for more stability? Or just add some weights to the bucket. Hmmmmm.....
Ken
