yes that what made me look there and that when I found that screwIs there by chance a wire hanging in that area not hooked to anything?
Or the oil should squirt out if the engine is running when you remove itTake the plug out and screw a cheap pressure gauge in the hole. Of course look for oil to drip out when you take the plug out.
You pull the plug and I'll bump the starter!Or the oil should squirt out if the engine is running when you remove it
Yep looks like it has good pressure! Want me to shut it off now?
