JB222
I have enough larger scale projects lined up for the Spring/Summer that I have started to think about picking up an older Lull. This would be for for the usual residential construction uses. Lifting framing lumber, a work platform for windows/siding, etc.. I dont have the budget for a newer model yet bat have seen some great deals on older ones.
In particular I spoke with the owner of this one I found on Craigslist
The owner is not terribly knowledgeable about the machine itself but gave me a good history. It was originally a rental for years and years then sold to a local contractor. This contractor used it some and sold it to another contractor a few years later. That contractor had it for roughly 6 years and put a lot of new parts into it. Paint, breaks, pistons, etc. This guy bought it from him just for one project and now it just sits.
It has 4wd, 3 way steering, and a Chrysler slant 6 (he says the 6 feels weak and might have some blow by). He says it is a 400s c1. Can you guys give me any advice on the capabilities of this machine for the type of work I described above? Also what sort of things should I look for when I go to check it out? Are there common wear points or major/expensive issues I need to worry about.
Thanks in advance guys.
