Long Reach worth it or not?
Discussion in 'Compact Excavators' started by Kenskip1, Feb 15, 2020.
  1. Kenskip1
    Kenskip1 Well-Known Member
    Feb 13, 2019
    61
    Missouri
    Well, I guess the title about sums it up.My mini of choice will be a John Deere model 35, or one similar to this size horsepower ext. My question is simply,what does the extra length (insert joke here) do for performance during excavation. I am able to understand the reach portion however the extra reach comes with a price. Leverage! Would the extra reach assist when pushing over a tree? I would also think that this leverage could work against the operator. Losing lifting capacity. That tree you just pushed over, now you are unable to lift it.So what it all boils down to, is the extra reach much more beneficial than the standard reach?Thanks, Ken
  2. AzIron
    AzIron Senior Member
    Jun 15, 2016
    857
    Az
    I personally dont think your giving up much to get more reach on a 7000lbs machine we always wish we had more power but for the most part you can operate around less lift or breakout but on my mini I am always wishing for more reach
    It's hard to operate around a lack of reach
    Mother Deuce and Ronsii like this.
  3. uffex
    uffex Senior Member
    Jan 23, 2012
    1,761
    Admin
    Lincoln UK
    Good day Ken
    You appear to sum it up very well a long arm will have a negative effect on lifting capacity - break out force - stability - the advantage is if course a small increase in reach - ground speed of the bucket. I suggest if you can manage without that extra leave it at the dealers, you may also take account of bucket couplers also increase reach and reduce bucket force. Reach can often be offset by moving the beast forwards or backwards.
    Kind regards
    Uffex
    Kenskip1 likes this.
  4. Don.S
    Don.S Well-Known Member
    Mar 29, 2016
    151
    Montreal Canada
    We had a short stick 27c and traded it in for a long stick 35d and would never go back. If you are always at the machine maximum you will be wishing you got a bigger machine. The only time i have ever wished i had a short stick is when digging under stuff since it makes the boom higher.
  5. KSSS
    KSSS Senior Member
    Feb 27, 2005
    3,083
    excavation
    Idaho
    Reach is always an issue with a mini ex, especially with one that small. I would likely go with the long stick and you get used to how it lifts and works. You will give up some ability on nearly every level of bucket and lift arm performance, but usually that can be worked around and dealt with. Pretty hard to add another foot of boom length.
  6. Billrog
    Billrog Senior Member
    Mar 27, 2016
    556
    band mill , backhoe and dump truck
    Armstrong, British Columbia
    I have a 7,000 lb machine and would sure like a little more reach . I would not be concerned about loss of performance, mine has plenty of power for the size. The convenience out ways any negative in my opinion.
  7. NepeanGC
    NepeanGC Well-Known Member
    Mar 19, 2017
    85
    #dirtherder
    Ottawa, Ontario
    Definitely long arm in this class machine. Not like it's gonna be bulking material all day where performance really matters. I did long arm and tilt-rotator on my 5 ton, which is technically the worst for breakout and digging force, but it works totally fine, since the machine is used for finesse and tight access work 99.99999% of the time.
  8. John Canfield
    John Canfield Senior Member
    Apr 27, 2009
    342
    Ranching
    Texas
    Sometimes I wish I would have ordered the long arm on my E42 but I just move a little closer to the work. I don't need more digging depth though - just a tad more reach.
  9. Clguest
    Clguest Well-Known Member
    Feb 3, 2016
    100
    USA
    Long arm here w E35 Bobcat...it also has a little more counterweight. Add my vote for the long arm.
    John Canfield and Kenskip1 like this.
  10. uffex
    uffex Senior Member
    Jan 23, 2012
    1,761
    Admin
    Lincoln UK
    Good day Folks
    Really surprised that few inch's should be such an advantage:- Op Diamensions.jpeg Kind regards
    Uffex
  11. Don.S
    Mar 29, 2016
    151
    Montreal Canada
    Its a foot of depth and a foot of reach thats a big difference. Its also the difference of loading trucks and not loading trucks.
    John Canfield likes this.
  12. KSSS
    KSSS Senior Member
    Feb 27, 2005
    3,083
    excavation
    Idaho
    That is a big difference. I had a CX160 that had a regular boom and my current one has a long boom. That extra foot and a couple inches is a lot more productive on digging foundations. It is hard to believe when you think how little the foot is on a 20 plus long boom, but it does matter. A mini ex always seems to need more dig depth or be able to reach just a little further when stock piling material. As long as you have enough machine to manage the extra boom length, I would always go with the long boom.
    Ronsii, Tags and John Canfield like this.
  13. NepeanGC
    Mar 19, 2017
    85
    #dirtherder
    Ottawa, Ontario
    Agreed. On a mini, a foot makes the difference between being able to see the bucket at the bottom of the trench, and having to work blind because the boom and bucket are completely stretched out and you have no reach. Does make quite a bit of difference in productivity too. An extra foot also means you can place excavated material further away, which means you can make bigger stockpiles before having to move.
