Thanks for the idea, I figured a rather easy way of doing it. I had an old plastic 55gal barrel laying around. The bung hole caps have a pretapped area in them were an outside faucet can screw in, all that needed to be done was drill a hole in the center of that. I then hooked my garden hose from the barrel to the tire bleeder valve. The barrel was laid on its side in the back of my truck. The faucet side was down leaving another bung cap at the top. I rigged the top cap up so that I could use my air compressor to fill the barrel. Once the barrel was full(took the most time, filling with 1gal jugs) of fluid I simply pumped air, every so often shuting the faucet of and bleeding the air out of the tire. I did set the compressor to 20psi and payed close attention to all fittings. This worked fairly quick and without much mess.
