excavator
I recently plumbed up a Linkbelt LX160 for a D&M Slashbuster head. We used a Lynch dual pump priority flow valve going through a DO5 valve, load sense for the Lynch valve was picked up at the pump Pi2 port T'd through a shuttle valve. The 2 pumps on the machine put out a combined 72 gpm and the head should have 35 gpm to operate. Currently the head is set at 30gpm/ 4200 psi and with it running the other functions on the machine are totally dead, in order to boom up/swing/travel ect. the operator has to turn off the head. It acts like the system is not sensing pilot lever movement when the head is operating. The machine had the pumps replaced approx. 9 months ago by the local Linkbelt dealer and seems to operate fine otherwise. I admit that I'm more of a Deere/Hitachi guy so I'm not real familiar with the Linkbelt system, at this point I'm more than a bit baffled. Any help would be appreciated. Thank you.
