Lighting and such
Discussion in 'Wheel Loaders' started by Dan O'Connor, Sep 22, 2022 at 2:12 PM.
  1. Dan O'Connor
    Dan O'Connor New Member
    Jun 13, 2022
    2
    ohio
    Hello, my facility has a Case W14B Wheel Loader, that I have been put in charge of maintenance since I have the most mechanical skills. I know that this unit is 24 Volt system, but does that include the lighting and accessories as well?
    I need to get the flashers working, as well as replacing some of the work lights. I'd like to replace all the halogen with LED's but wasn't sure if I could just wire them up to the existing wires.
    I'd appreciate any help and info.
  2. heymccall
    heymccall Senior Member
    Feb 19, 2007
    3,920
    White Oak, Pa
    Odds are that everything is 24v. Only you can verify, by measuring voltage at one of the lamps.
    Anything less than 2500 lumens in an LED isn't worth using as worklamps.
  3. rockfarm
    rockfarm Member
    Sep 10, 2022
    17
    lethbridge
    system should be 24 volts and yes it does include lights and accessories. I've changed out our machine's halogen lights for LED's. the LED's we bought worked from 9 to 32 volts. for work lights we did not go less than 80 watts and yes, less than 2500 lumens doesn't cut it for work lights. It should not be a problem to use existing wires.
