Lifting eye or chain hook?
Discussion in 'Compact Excavators' started by John Canfield, Jan 28, 2019.
  1. John Canfield
    John Canfield Well-Known Member
    Apr 27, 2009
    209
    Texas
    Other than using a chain over bucket teeth for lifting, what other options are out there for a more dedicated solution? What about welding a chain hook either inside the bucket or the backside near the attachment point? I have a ripper ordered for my E42 (also on order) - would that work well with a chain looped over the tooth?
  2. lumberjack
    lumberjack Senior Member
    Dec 25, 2011
    1,013
    Columbus, MS
    I weld a swivel d ring on the back of the bucket for a lifting point... works great and stays out of the way.
  3. John Canfield
    Apr 27, 2009
    209
    Texas
    Ah, right - hadn’t thought of a D ring, I welded some on my trailer. Great idea, thanks!
  4. Canuck Digger
    Canuck Digger Well-Known Member
    Dec 24, 2012
    176
    Business Owner, Equipment Operator, Fishing Guide
    Mission, BC, Canada
    I like lifting eye with a removable shackle/lift hook that rotates. Allows you to swing loads around as you need them to. The nice thing about a lift hook is if you're using straps all 4 ends will fit. I like the removable shackle cause the constant banging of the lift hook against the back of the bucket drives me crazy, so I just remove it and only put it on when I need it.
    InsleyGuy, grandpa and John Canfield like this.
  5. John Canfield
    Apr 27, 2009
    209
    Texas
    I know about shackles banging, I had them on my rock crawler Jeep. Drove me nuts. Haven’t heard of a rotating lift eye, I’ll have to investigate.
    Apparently Bobcat has a bolt-on lift eye, found it in their online parts catalog. It looks like you would want to use it without a bucket. The parts diagram for that eye shows it mounted above the X-Change.
  6. Canuck Digger
    Dec 24, 2012
    176
    Mission, BC, Canada
    If I'm not mistaken, the new Hyundai series has the same system when I was looking at their 60. the only thing I didn't like about it was the eye stuck out quite a ways past the back side of the bucket. Could cause some damage on siding and such thinking you still got a few inches. On the flip side, if you're lifting things that you shouldn't be weight wise, would be nice to lose the bucket and gain a few hundred pounds in lift capacity...
    John Canfield likes this.
  7. John Canfield
    Apr 27, 2009
    209
    Texas
    I was thinking along the same lines - drop the bucket and gain more lift power.
  8. rondig
    rondig Senior Member
    Jul 24, 2013
    481
    excavation
    fort macleod alberta
    We made a short jib that we quick attach without bucket. It works great for building mega block retaining walls in tight areas. Also gives extra reach
  9. Nige
    Nige Senior Member
    11,217
    What about something like this..?
  10. John Canfield
    Apr 27, 2009
    209
    Texas
  11. DMiller
    DMiller Senior Member
    Feb 22, 2010
    5,278
    Retired
    I generally chain out what I am lifting, sewed on 1/2" weld on Chain hooks for myself.
  12. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    3,474
    Moose Lake, MN
    This one would meet OSHA requirements as well providing you used a shackle to attach your rigging. D rings, open hooks without retainers, etc. are not OSHA approved. Plus its always nice when everyone goes home at night healthy and unhurt.
    John Canfield and DMiller like this.
  13. lumberjack
    Dec 25, 2011
    1,013
    Columbus, MS
    OSHA has a problem with D rings, but DOT likes D rings for load securement? Learn something new every day.
  14. John Canfield
    Apr 27, 2009
    209
    Texas
    All of the D rings I've ever seen are Chinese made which I don't trust - I never place myself under a load using a D ring anyway.
    DMiller likes this.
  15. ITW
    ITW Well-Known Member
    Feb 8, 2019
    78
    Norway
    I use one like this welded to my quick connection
    Than I can remove the bucket for maximum lift and it is no problem to use with bucket on also.
  16. Jbullfrog
    Jbullfrog Well-Known Member
    Mar 5, 2011
    75
    Avoca, Iowa
    Lifting plate side - postable.jpg Lifting plate  back.jpg I have a Werk-Brau pin grabber, so I had a local shop plasma cut the side plates to make this. It is a section of 2" square tubing with a Warn recovery hitch insert. It will take any receiver hitch to move trailers around also. I use 1-3/4" cylinder rod for the pins.
    mikebramel likes this.
  17. Nige
    Nige Senior Member
    11,217
    Pardon me for asking but isn't the attachment kind of a "sloppy" fit on the pins or is it just an illusion of the photo..?
    Just thinking out loud that you might run into issues with a Safety germ unless the fabrication was "engineered" (in as much as stress calculations were done) and there is no SWL marked on it.
    Don't get me wrong, as a fabrication it's neat and it will do the job. But I have experience of how this sort of stuff can go South in a heartbeat.
  18. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    821
    Equipment operator,mechanic
    S E Pa
    1BE5A642-5203-4541-96AC-0F8EB4D4F2B9.jpeg I like these
  19. Jbullfrog
    Mar 5, 2011
    75
    Avoca, Iowa
    The pins fit tight in the plate sides, the collars are just to hold the bolt retainer.
  20. Nige
    Nige Senior Member
    11,217
    Thank you. An illusion of the photo in that case. I always think that if something looks right it most probably is right.
    A nice paint job and a neat plate with the SWL marked on it would be the perfect finishing touches.
