farmerlund
So a friend of mine has a IH truck around a 2000-2001, the front cover has a crack in it and leaks a lot. we stop drilled the crack and tried sealing it with belzona. It acts like the cover is pressurized or full of oil when running.
I am not familiar with these little motors, does it have more oil behind the cover than i think. the crack is above the crankshaft a ways up. Can a drain be plugged not allowing oil to drain back to the oil pan?
It does have a fair amount of blow by when running. just seams like to much oil comes out of the crack.
it doesn't get a lot of miles on it so he is just trying get the leak stopped.
Thanks
Thanks
