Lil'Puss- the valve I used was selected based on the flow, 10 GPM. I can put you in touch with the company I bought it from, Tennesee Hydraulics. I can pm you his e-mail. He is very knowledgable on electric valves. This would be an easy job on your dozer, as you would have to fab very little. Is you Dozer 6 way? It would be so nice to use a 2 function valve, one for tilt, one for up-down. Stuve- the wheels would be great if I was doing alot of fields, or other very big jobs. with the wheels, you get the "grader" effect and is alot more accurate. To give you an idea what I do with it, my first job was inside a new riding arena. 45000 sq ft, and the grade left by the excavator was very bad. I had to grade in and around many obstacles- support beams, stalls, etc. When done, it was within 1/2", no sense in any better. Could not have been done as well with wheels IMO. When grading, the box goes where the laser tells it to, shoes would not be needed. It is a regular quick attach, ( I promise more pics) it is not on the machine all the time. Changeover is about 7 minutes, 4 hydraulic conections, bolt up the coupler to the loader arm, wire up the box and away you go. 90% of what I do with it is backwards like any box scraper it is drug not pushed. 15 years ago I had another "idea", made alot of money-for the patent attorneys. So anyone is welcome to run with this. Good luck!
