Bought a 4 years old Takeuchi TB219 excavator. It got 2000hours on the meter, and seems to be in good shape. No excessive wear, engine and hydraulics are also looking to be clean.
I experience some of the hydraulic operations to be a bit weak.
- I cannot lift the excavator with both boom and doozer blade at the same time.
- When I lift the boom with max lifting capacaty, and then lift the arm or bucket, the boom will give in for the load, and lower it self.
- The tilt on the bucket seams to be weak, and will give in if I force it into the ground.
These are the symptoms I remember tonight, and after the searches I`ve done, I find the pump to deliver accurate pressures. P1 gave 215 Barg, and P2 gave 221 Barg. P3 and P4 havent been checked at this point, but I think they are good.
The noise when I fully extend boom, arm and bucket reminds me of the sound the reliefe valve will make.
Do anyone have any good tips to check?
