Se.la
It all started 1 week ago, a few times a day the engine has a max RPM of 1600rpm, I shut off the engine and restart it and everything is ok, this happened 2 or 3 times a day, but yesterday it happened 20 times . No error code appears when the problem occurs in the display. I have checked the code recorded in repair mode and PSID96-01. I checked the solenoid of the fuel rugulator = 3.2 Ohm Has anyone seen this problem before? Regeneration works well Stall test = 2090rpm Trans and Hyd Thanks for your help.
