L45b loader circuit board output voltages
Discussion in 'Compact Wheel Loaders' started by joellangeman197, Sep 14, 2015.
  1. joellangeman197
    joellangeman197 New Member
    Sep 14, 2015
    2
    Heavy duty mechanic
    cranbrook
    Anyone here have any knowledge on L45b output voltage from circuit board to fuel shut off solenoid ? :bash
  2. Ben Witter
    Ben Witter Well-Known Member
    Apr 3, 2013
    233
    On the outside
    Feed to shut down Solenoid should come out of connector X108 (on circuit board) pin 9 through connector X22(off main harness) pin 4 and onto the solenoid connector Y6. Earlier machines were fed directly via fuse 25 and later were fed through the ignition switch via fuse 23. Should be battery voltage.
  3. joellangeman197
    Sep 14, 2015
    2
    Heavy duty mechanic
    cranbrook
    pin 9 with key on has 4.5 volts could it be a load sensing circuit? and the solenoid is just cooked ? 15.4 ohms R at solenoid
