SeaMac
Yet again,
Another thread created with no real proper forum to post in. I think it's fair to say we have all encountered light towers, mostly the lights are a gang of four (4) where one or more usually doesn't work. Alas, there is a solution Light Emitting Diodes (LED) with LED's not only do you get far and away more light, you also get it at a great cost savings in fuel.
The average light tower sports four 400 Watt Metal-Halide lamps with associated ballasts and being made of glass they do not fancy being towed around on a pintle hitch behind a pickup, stowed upon the back of a flatbed truck or slung about on the forks of a loader. They were never intended to be mobile, rather they prefer to be perched atop light poles at a car dealership. The average life expectancy of a given metal-halide lamp is approximately 5000 - 7000 hours and that again is considering a FIXED location. These lamps and ballast are not cheap by any means to replace.
Now, with an LED light tower they are immune to movement save for a hurricane or earthquake, cost pennies to operate and will last on average 50,000 - 70,000 hours. Yes, you read that right and no, I'm not bull.... I am an Electrical Contractor too. True enough, the initial cost is high and in the past the color spectrum was so glaringly white it bordered on blue. Lighting manufacturers have since rectified the color issue and through what is called "binning" the color across the led board will be consistent.
Now about cost, yes they are expensive but only your great grandchildren will need be concerned with replacing one that burned out. Then there's the fuel cost, since most light towers run on diesel and we all know that particular petroleum by-product is now thought of as gold by Big Oil, we'd surely rather use less not more. An LED light tower will astound you with how little fuel it would use AND the genset providing the spark to make light could be much smaller as well, so now we have a fuel and weight savings which in short order will assuredly offset the initial cost tremendously.
In summary, LED lighting is here to stay, you see it more and more on cars, trucks even heavy equipment. We have a new bridge here with all LED street lighting and the view is amazing so it won't be long before LED light towers will be on a jobsite near you if not already. Oh yeah, another nicety of LED's they attract less bugs...
