KVGT issue
Discussion in 'Excavators' started by Vetech63, Sep 11, 2019.
  1. Biglou101
    Biglou101 Member
    Feb 7, 2020
    7
    Pennsylvania
    PC228USLC-10
  2. Biglou101
    Biglou101 Member
    Feb 7, 2020
    7
    Pennsylvania
    PC228USLC-10
    Slightly different Than OP but I thought I could use most of the tips and Hints.
  3. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    4,534
    Mechanic
    Will county Illinois
    Still, all valid info, you are correct.
  4. Biglou101
    Biglou101 Member
    Feb 7, 2020
    7
    Pennsylvania
    My pressure seems to be about 15 psi below minimum, is there a way to check the relief valve or will whole pump need to be removed.
  5. funwithfuel
    Mar 7, 2017
    4,534
    Mechanic
    You're above 125, yer fine. It's just control pressure to exercise the functions
  6. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,726
    Oklahoma
    Im glad FWF is here! Do everything he says as he is the resident expert on Komatsu stuff. JohnC. is good info also!
    mg2361 likes this.
  7. Vetech63
    Aug 10, 2016
    4,726
    Oklahoma
    Just to chime in...……...is there any current active fault codes on the monitor? It sounds like something else may be going on.
    mg2361 likes this.
  8. funwithfuel
    Mar 7, 2017
    4,534
    Mechanic
    Oh no, not even close, I'm just a fill in when John C is busy
    mg2361, John C. and Vetech63 like this.
  9. John C.
    John C. Senior Member
    Jun 11, 2007
    11,709
    You can give yourself more credit than that! I know a little about 15 year old stuff. I think you got the new stuff better than my old brain can sort through.
  10. funwithfuel
    Mar 7, 2017
    4,534
    Mechanic
    My noggin is stuck in Volvo operating systems. I find it makes it difficult to grasp how Komatsu works and Liebherr for that matter. Slowly coming around though.
    When it comes to engines and their operating systems, I try really hard to stay current .
    mg2361 likes this.
  11. John C.
    Jun 11, 2007
    11,709
    With engines, I’m not going to try any more.
    Ronsii likes this.
  12. DK88
    DK88 Senior Member
    Jan 19, 2011
    320
    Field service tech.
    Ontario
    you guys are good, typically the screen in the bottom of the rgr housing plugs easily, if its clean and good pressure from the boost oil pump, pull off the epc for vgt control and clean it well, and iirc correctly there is 2 screens under the block with the oil feed line on the tubro, the 125/140 engines plug them all the time. if no change change the turbo, ive changed a few for the helicopter noise your hearing.
  13. Biglou101
    Biglou101 Member
    Feb 7, 2020
    7
    Pennsylvania
    Machine came back after working fine for a week, doing the same surge and had a fault for ca2554 exhaust back pressure sensor in range low. Surging again, replaced sensor and cleaned tube to manifold. Code came back for turbo position fault and machine continues to surge.
  14. Salfred
    Salfred New Member
    Jun 15, 2021
    1
    S.C.
    I don't know if this will help you but I have the same code CA2387. Checked the oil pressure for the EGR valve and KVGT. all of my pressures were good. the position senor for the KVGT was also good. I looked on the monitor and the position for the KVGT would stay at .018 and would not change. I replaced the turbo because the vane plate was stuck. After replacing the turbo machine ran good KVGT valve would stay around .213. The code went away, I ran the machine for 30 min no problem. Got a call the next day for the same code. Looked at the valve and it was stuck on .132 and would not change. I removed the turbo and disassembled. Some debris had gone though the turbo and bent some of the fins so the vanes could not slide though the plate. The engine seems to run to good for a piston or valve be damaged. the machine is on its way back to the shop now. Anyone have any suggestions on what it might be. Anyway maybe this will help you. I apologize if any of the terminology is wrong.
    LACHAU likes this.
  15. davecampbell
    davecampbell Senior Member
    Jan 20, 2012
    348
    Oklahoma
    my pc210-10 just threw this code. Disassembled turbo and all looks good. Going to try to find screens tomorrow. I've had low boost pressure as long as I've owned it. Komatsu says I should hit 31psi and 26 is best I've seen, normally varies from 15 to 21. I had intercooler pressure tested.
  16. John C.
    Jun 11, 2007
    11,709
    What are you using to measure boost pressure? The onboard electronics?
  17. davecampbell
    Jan 20, 2012
    348
    Oklahoma
    yes, just chosing the custom monitoring in the screen. On the predetermined monitoring I noticed oil switch is off! Is thT for oil pressure or level? How can I turn it back on?
  18. davecampbell
    Jan 20, 2012
    348
    Oklahoma
    I've taken the turbo apart and cleaned the carbon off of the VGT so insure it is not sticking. I've cleaned the 2 screens in the top of the turbo as well as the on at EGR inlet. I'm seeing vgt positions up to .220 and down to .150 during operation. It indicates .000 when engine is off. If those values are normal then I think I can look elsewhere, if those are not then ill try running pressure check on oil supply. this machine has never boosted over 25psi for the few months I've owned it. Komatsu says it should hit 31psi. anyone else have one of these machines and willing to share their numbers?
  19. John C.
    Jun 11, 2007
    11,709
    The engine will only develop the amount of boost needed to carry the load against it. Have you checked your boom up cycle time? The system is load sensing.
  20. davecampbell
    Jan 20, 2012
    348
    Oklahoma
    I can go check that. I was maxing out bucket curl to load it. After it throws the code it seems to de-rate and get really weak.
