Mine does not have a built in beeper defeat switch. I did get a separate install sheet on installing the beeper, seems it was done by the dealer, as an option I believe, which at least made it easier to figure out how to (when the situation warrants) defeat it.
So far, I have been able to get level enough (at least it felt level enough), using the blade only, I was thinking if working up hill, blade behind me, and needing a bit more blade down to level things up a bit, throwing some dunnage/cribbing under it would be one way. Again (and here's where my hoisting experience could bite me in the a**, I am used to doing so when setting up. One big difference of course, now that I think about it, is the crane isn't getting pulled forward or back by the digging action, all loads are, hopefully anyway, plumb, or exerting no forward or backwards pull. I used to be a big time ultralight aircraft builder/dealer/seller/ trainer, and some of my worst customers and students were long time conventional pilots, I had to work around their prior experience, some of it good, some of it not applicable, same thing here with me getting lined out on this digging machine! Got a picture of your blade extensions? So far my uphill (18 degrees anyway, with no side slope, and only minor slewing required) work has been working my way uphill, the next part I will be working my way down.....
I'm in mode A, that's how it came, and for some reason, it immediately felt right to me, and how I am now used to it. If I need to grade much I'll use the tractor scraper blade. I'd like to say to say I studied the operator manual carefully and took notes before getting into the seat for the first time, but I'd be lying. It arrived around midnite, and I fumbled my way through walking it off the trailer, the next morning, due to having a few days off work (rare) and an urgent need to get my project underway before things dry out and fire season arrives, I immediately got to work. RPM's? I have no idea, but just enough to not lug it down and not too much to feel like I'm racing it. I have not looked. I checked out the big boulder i moved again, it was fully 3' across, but only about 2' deep, but I was able to cleanly pick it. The few times I've picked boulders with my crane have taught me that boulders, even similar appearing ones, can vary vastly in weight, a geologist could explain this, from heavy, to really heavy.
Fuel consumption seems to be similar to my 20 HP old Kubota, as in almost perpetual motionish, at times it almost seems like it's producing fuel. Let's just say "not much", no numbers yet, assuming the dealer topped off the tank as I asked, I'll figure it out in a while, but it's already obvious that it's so low it's almost irrevelant! My new L3301 K tractor on the other hand, actually consumes fuel, probably twice as much as my older one, sounds like your U 35 was more like that. Yeah, the lack of noise the U25 makes is great, (and all the more surprising the power it has) I am thinking of installing a docking station for my Siruis sat radio, along with a couple weather resistant speakers on the ROPS, I wouldn't be without my Sirius in the crane as it keeps me entertained and informed, and from falling asleep.
