chrisdvorak
Picked up a 02 l35 Kubota recently and noticed that when you move the shuttle lever to fwd or rev there is a slight chirp as the clutch pack engages? no delays in shifting or any other issues with the trans just seems like an odd noise for a wet clutch to make upon engagment. will do it more commonly when its cold then when its warmed up. also had a l3010 with GST trans that did the same thing, no other issues either just the annoying noise. hyd fluid is clean and filter was changed not long ago. any input would be appreciated.
-thanks
-thanks
