posrepair2013
I am working on a kubota kx080-3 v3307 engine with 8k hours.
What's happening is when u are running hydraulics its killing engine u dont even have to be digging if u run a cylinder all the way out of in and hold it for a second engine will stall.
It does it when machine is hot or cold.
I have by passed fuel system( installed my own pump, fuel filter , fuel tank)
Checked boost pressure the highest it gets is like 15 psi before it dies (seems a little low to me)
I'm waiting on a compression test fitting just because I want to eliminate engine before I go to hydraulics.
It does blow a little black/grey smoke when it loads up before it dies.
Any suggestions or advice would be great thanks
