kubota engines synthetic oil
Discussion in 'Skid Steers' started by xkvator, Apr 25, 2005.
  1. xkvator
    xkvator Senior Member
    Apr 9, 2005
    258
    pa.
    anyone using synthetics?
    i've been using Mobil 1 - 10w-30 in a bobcat 751 and this last oil change put in Delvac 1 - 5w-40.
    changing oil now in a 331D...used Bobcat brand 10w-30 the first couple changes - have the Delvac & also Rotella synthetic(walmart $13/gal).
    anyone know which company makes the oil for Bobcat?
  2. choober
    choober Member
    Jun 7, 2009
    10
    Wellington. OH
    Synthetic oil is the best way to go. Especially in an air cooled machine.
  3. John DiMartino
    John DiMartino Super Moderator
    Oct 30, 2003
    94
    Greenskeeper/mechanic
    Walden, NY
    Whatever synthetic is used,make sure the API label starts with a C for compression ignition engines! Ive seen many ppl think they can use regular Mobil 1 10w30 car oil in there diesels,and you can't.Gasoline oils the label starts with an S for spark ignition.This is VERY important,as you will eventually cause damage to your diesel by running car synthetic oil in it.There is a huge difference in the oils propertys,ability to hold soot,and film strength among other things.
    I would use only 5w40 full synthetic in a skid steer,it will pour well at -40 zero,and protect better in 100 degree weather than conventional 15w40 oils.
    Also all 5w40's are diesel oils,it is difficult to find diesel rated synthetic oils in any other viscosity.
  4. k45
    k45 Well-Known Member
    Mar 25, 2009
    148
    southern Ohio
    IF oil is changed at proper intervals, is there really and advantage of going to a synthetic oil on a diesel?
    Do diesels wear out if properly maintained?
  5. bgirls
    bgirls Member
    Dec 14, 2008
    11
    IT director, Transportation director
    Flint Hill, VA
    every piece of equipment i own is filled with synthetic oil or grease including the lawn mower.
  6. John DiMartino
    Oct 30, 2003
    94
    Walden, NY
    The biggest advantage to running it is during cold starts and operation,and at high temps.Cold starting is much faster and easier on the starter motor,esp in winter.Engine life is extended thru getting pressurized oil faster. If your diesel has a turbocharger,which most do anymore,the synthetic offers a huge advantage at hot shutdown time.Coking of the turbo bearings is much less likely since the synthetics do not boil until well over 400 degrees,most offer a 100 degree higher temp than conventional oils.When your turbo is at 600 degrees and you shut it off,synthetic oil will not boil off once oil flow stops like regular will.
