Komatsu turntable
Discussion in 'Excavators' started by Bertrrr, May 23, 2020 at 9:34 PM.
  1. Bertrrr
    Bertrrr Well-Known Member
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    I have a Komatsu PC128 that will not rotate , there is no grinding or any noise other than the engine straining to make the turning motion all other hydrolics work fine it just will not rotate , I'm thinking the selector valve is the issue but all other functions respond. I am not very familiar with these machines so any help or suggestions would be great , thanks
  2. mikebramel
    mikebramel Senior Member
    Jul 16, 2012
    1,597
    milwaukee
    If the engine is straining..... is the brake releasing
  3. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,210
    Equipment operator,mechanic
    S E Pa
    Something jammed in the ring and piƱon gears?
  4. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    Not sure about the brake releasing or how to verify, the engine does strain like it's trying to turn the machine, it's the ONLY function that does not work , just cleaned it up with a pressure washer to check for leaks and what not
    does it get an electrical signal to function ? or is it a set of hydraulic valves to make it operate ? I do not see a bunch of hydraulic lines running to the joy stick area but it seems to be getting the signal to move being the engine strains when the joy stick is telling it to rotate. I do not think there is anything jammed into the gear area b/c it had been rotating before then was intermittent in the rotating function , thanks for your replies
  5. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,320
    It seems fairly clear that the swing brake isn't releasing.
    I'm not familiar with this particular machine, but look for a solenoid valve on the swing motor not getting current, or maybe a small diameter hydraulic line going off to a manifold somewhere with the solenoid.
    John C. likes this.
  6. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    Thanks for the input , this makes sense to me , now to figure out where the solenoid valve is and why it is not getting the signal
  7. tool_king
    tool_king Senior Member
    Mar 29, 2010
    1,553
    road mechanic owner
    new jersey
    What dash number is it ?
  8. John C.
    John C. Senior Member
    Jun 12, 2007
    7,597
    It's a zero tail swing machine so everything is packed in tight and usually hard to see and harder to get at.
    The swing brake is controlled from the computer. The brake is on all the time when nothing is being used. When a function is used a pressure switch for that function closes sending a signal to the computer which grounds the circuit for the swing brake solenoid which operates a pilot valve to release the swing brake. When everything stops the computer waits for approximately seven seconds and the sets the brake again. I believe you stated in another thread that the wiring is all torn up on this machine so I would suggest your problem is there. You can find the solenoid by following the small hydraulic hose connected to the base of the swing motor back to the solenoid block. You should see a stack of four solenoid coils on that block. From that point you can check the wires and harness.
    Time to get dirty.
    Vetech63 likes this.
  9. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    thanks so much for the input, I will try and locate everything this week and figure out where the problem is will update when I know something else or have another question
  10. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    I found what I think is the swing motor / brake solenoids , planning on jumping 12 volts to each and see if it will allow the machine to swing , not sure if it needs 12 or 24 volts though
  11. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,320
    There's no guarantee that it's either 12 or 24v. If it's controlled by a computer it could be as low as 8v or it could be PWM operated. If there is nothing written on the coil indicating its voltage, apply battery voltage to it very briefly to see if the brake releases. If it does, you've proved that the fault is either in the computer or wiring and proceed from there. If you wire it permanently to the battery, you risk burning it out.
    mikebramel likes this.
  12. John C.
    Jun 12, 2007
    7,597
    You will need to supply a serial number or at least a Dash series of the model number. It will read PC128-?. All the Komatsu excavators I've worked on were 24 volt. You can check the coil with an ohm meter. They run about 7 ohms normally. They are bad when they read zero or infinite. Coil wires hook to the wiring harness with a connector that will have a number tag on it.
  13. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    Think it reads PC 128-UU , this machine has been neglected and rigged 7 ways from Sunday so it's a jigsaw puzzle at this point, thanks again for your input guys , will update tomorrow after I run some tests on the solenoids
  14. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    These 2 pics show a number of solenoids that I assume have to do with the swing brake,
    can you guys help identify this group ? none have any wiring connected at this point, I did apply 24 vts to one of them and it clicks like it's activating , thanks in advance IMG_0570.JPG IMG_0571.JPG
  15. John C.
    Jun 12, 2007
    7,597
    The purple paint tells me the machine is a gray market machine. There were four solenoids on standard machines. They were for two speed travel, swing brake, CO cancel and arm half flow as I recall. The first generation machines had some big differences though so I can't be sure of what is in yours. I don't recall there being two different manifolds for the pilot system either.
    If you can feel the solenoid click, it is OK.
  16. Bertrrr
    Sep 5, 2016
    59
    mechanic
    South Louisiana
    one of them clicks , none of the other ones make any noise , checking voltage on the wiring that goes to this group, there is about 20 vts when the machine is running , I touched each one off with 24 volts but didn't seem to have any effect. Can you identify the two solenoids on the top near the swing motor ? I haven't tried those yet
  17. John C.
    Jun 12, 2007
    7,597
    Best I can tell you for identification is the follow the hoses to the components.
