Komatsu plus vs conventional undercarriage
Jam
Cork, Ireland
Building contractor
Hello all. I am about to change out the undercarriage on a px61-23 and looking for opinions on which system to go for. Currently machine is on the plus undercarriage but link shoulders are failing at 4000hrs. Conventional is about 1/3 cheaper up front but will I regret it? Machine mostly does grading with a laser setup
Vetech63
Oklahoma
That is a common problem here with that type of undercarriage. It also take special tooling that is expensive as hell. I have replaced several with the standard undercarriage with no further issues.
Jam
Cork, Ireland
Building contractor
Was there any downside you’ve noticed? Life span of the system, noise or blade bounce?
nicky 68a
england
Here in the UK,many of these class tractors have been replaced with conventional non oem undercarriages
  • Like
Reactions: Jam
Jam
Cork, Ireland
Building contractor
I decided not to replace with the PLUS system and bought a Komatsu HD AR system which uses conventional SALT chains with hardened links. The biggest downside is the pads won’t enter change between the systems but I’ll change everything out and it will be good for a long time to come again hopefully. Thanks for the help.
Dave Neubert
Monroe NC
Got a customer with a PX39 he has had to replace 4 links he said it cost him $2500.00- $3000.00 each time they come out I told him to go with old style he already paid that much in changing links
Jam
Cork, Ireland
Building contractor
Sounds like the "plus" is just more money for Komatsu selling new links.
The frustrating thing is the rest of the system shows very little wear. It’s like the external link isn’t heavy enough to handle the horsepower on the widepad?
John C.
You are just seeing the field engineering data showing up. I would suspect that the width of the pads will be the deciding factor in the future on which type of chains are used. The thing about the Komatsu system is that the idlers and rollers haven't changed, unlike the Caterpillar system.
  • Like
Reactions: DB2
Jam
Cork, Ireland
Building contractor
Components arrived this week.
wee_gus
Scotland
Here in the UK we have been converting both cat and Komatsu dozers over to SALT chains, done a few Komatsu this year and not one had done over 4500 hours
  • Like
Reactions: Jam
Sounds about right. Some of the larger machines might go a little longer with extreme HD undercarriage.
