NCMilt
Call this a restoration project...
Suddenly, I can't raise the boom on its own nor move the bucket with any strength.
The boom budges, but won't lift. The bucket will move through most of its travel if it has no resistance.
Strangely, if I push the stick out, and pull up on the boom, it will raise, slowly, while the stick moves. Almost like I'm pumping it up with the stick..
This machine has 3 valve blocks:
1 controls the blade.
The next controls bucket, boom, offset & right track. I can't load the offset to test its strength. It moves fine. That probably doesn't mean much. But the bucket, boom, and right track are very weak. Except when I operate something on the next valve block at the same time. Still weak, but much stronger.
The third controls left track, stick, and rotation. All these seem fine.
Why would operating valves on the 3rd block assist pistons attached to the 2nd?
What's wrong with my machine?
