Komatsu PC75uu-2 pump parts
Discussion in 'Excavators' started by Jon Bradtke, Aug 11, 2019.
  1. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    I just picked up an older Komatsu PC75uu-2. The previous owner said it needs pump work. Took it home and sure enough, I got 2,200 psi on 1 valve manifold block and 0 psi on the second valve manifold block. The third manifold block comes off the gear pump at the end of the piston pump and that one was at 3,000 psi. I actuated the track levers for testing the main manifolds as to avoid throwing the pilot lines into the scenario. Has anyone tried rebuilding a PC75uu-2 main pump themselves? And if so where did you source your parts from? The dealer wants an obscene amount of money for OEM parts and I don't want Chinese parts if I can avoid it. Any suggestions would be great.
    Thanks,
    Jon
  2. John C.
    John C. Senior Member
    Jun 12, 2007
    6,901
    Komatsu for the most parts makes its own pumps so you have just stated the only sources of parts. It's a grey market machine as well. Good Luck.
  3. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    How do you know it’s a gray market machine? And I believe the pump is made by Uchida because that is what the parts manual says.
  4. John C.
    Jun 12, 2007
    6,901
    That model of machine was never sold through US dealers. I've never seen a Uchida pump on a Komatsu. Now it sounds like you have something European or custom. You might post of the photo of the pump and maybe someone here will recognize it.
  5. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Okay thank you for the information. Attached pictures of the pump. Just took it apart this morning. Completely shot. Looking for any recommendations at this point for parts. Here’s 4 pictures and I’ll reply with more pictures.
  6. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Here’s a few of the internal pictures.
  7. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    And some more....
  8. John C.
    Jun 12, 2007
    6,901
    All I can say is wow!. I don't think I've ever seen one that bad. Is there a tag with any numbers on the pump? If you have a book, you might be able to plug some part numbers into Google and see what you get.
  9. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Me either! No serial/model tag on the pump. Just casting numbers which are typically useless. Dealer sent me a parts breakdown of the pump and the pump assembly part number is 21W-60-22111. I’ve been googling trying to find parts but all I find is Chinese parts. See attached parts breakdown from the dealer. It says Uchida on the parts breakdown which is why I was asking for that brand in the beginning.
  10. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Here’s the correct page for the cylinder block, pistons, etc.
  11. John C.
    Jun 12, 2007
    6,901
    Uchida used make pumps through licensing of Rex Roth designs. You might try calling someone through them. I've never heard of Yuatsu Kiki before.
    It might be Komatsu only for parts. I've seen some bad stuff from China and Korea for pump parts. How much money are you looking at for parts or a pump from Komatsu.
  12. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    8.7k from Komatsu not including the swashplate which I wasn’t including in my original quote. Probly over 10k with the swashplate.
  13. f311fr1
    f311fr1 Senior Member
    May 12, 2016
    557
    Middle TN
    Bear Industrial Group, Mt Clemens MI. 586 792 2800 Specializes in Jap hydraulic brand repairs
  14. f311fr1
    May 12, 2016
    557
    Middle TN
    Once upon a time Uchida was the Rexroth licensee in Japan. Try Engineering Technology Services , Memphis TN, 901 369 5404. They are the largest independant Rexroth repaie house in the US.
    Vetech63 likes this.
  15. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Thank you so much I’ll give them a call tomorrow morning!
  16. JBGASH
    JBGASH Senior Member
    Jan 1, 2011
    752
    Plumbing & Excavation Contractor / farmer
    Missouri
    If it like my 75-uu-2 it has a Uchida- Rexroth pump. They are rebuildable from some hydraulic rebuilders and some new /aftermarket replacement pumps are available.
  17. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    I’d like to rebuild it myself. Any leads on where to find parts? Do you mind saying how much you paid for your pump?
  18. Smedlow
    Smedlow Member
    Jun 14, 2017
    6
    Alaska
    Several years ago my pump went belly up and, as you said, it was a Uchica-Rexroth pump. I bought a replacement (rebuilt) from the outfit I bought the Excavator from, and they charged me $8000, delivered in Alaska. I installed it and the pump has run fine, but pieces of the old pump were all throughout the hydraulic system. I took the main valve body out and had it rebuilt. There were many little pieces in there. I replaced filters after an hour, and then after a few hours, and then normally. New fluid, of course. Wasn't the most fun I've ever had, partly because it died in my daughter's front yard just as winter was setting in, so I didn't finish the job until spring.
  19. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,907
    Oklahoma
    A downed excavator makes a good mailbox post in this scenario.;)
    mg2361 likes this.
  20. Jon Bradtke
    Jon Bradtke Member
    Aug 17, 2017
    15
    New York
    Just brought the pump to a local hydraulic repair shop. They quoted me from the same parts dealer that I was planning on buying from. $1100 for me to buy parts (Korean made) and I asked them to quote the assembly of the pump. Hopefully it's not too much!!
