More and more of these types of screwups are telling me I'm getting too old to be driving and operating equipment. I'm nearly blind in my left eye, which made awareness of things on the left of my machine very limited.
I think what I'll do is take the door off and try to straighten it using various leveraging methods.
The glass is flat, but it's an irregular shape. Someone with a waterjet cutter can easily make it, I'm sure, but not sure if any such sophisticated fabs exist near me.
I'm clearing some land for a second solar array. The last half of the red oak I cut was like one of those building demos gone wrong.. the tree started to lean, but wouldn't go over. So I drove the machine into the wooded area in the midst of the remains of a a large pine that I'd pushed over last month. I'd started to cut the tops, but shifted to other more urgent projects and so the pine was there with butt ends of its trunk about 5' in the air. When I started backing out after pushing the oak over, it seemed like I was backing into a hole, so I decided to swing the house around and drive out straight, but that's when I got snagged in the pine trunks. Was somewhat tired after all that cutting. I'd built a platform on double cinder blocks about 2' off the ground so I could reach the individual trunks where they split from the base of the tree. I was cutting with the saw just above eye level to cut the wedge out, it was quite strenuous and nerve-wracking. My wife said "you're crazy!" as I was on the leaning side of the tree. Then I moved my platform and did the back cut. Got out of there as soon as the tree started to come down, but then it stopped. That's when I decided to bring in the machine to give it a little nudge. What I should have done after it was all done was back out the way I came in rather than turn the house around. Dumb decision on my part...
