Mark A Weiss
Clear vinyl hose is a good replacement for the sight glass. I have one on a hydraulic tank that is pressurized to 15 psi.
Another option for the broken bolts.↓
If you have the room, cut that nut off with an angle grinder or, drill a hole next to those broken off bolts and use a new nut and bolt.
An angle drill may be a good choice for a drill.
Any recollection what size hose fits that sight glass fitting? Maybe I can pick some up at Home Depot hardware.
My neighbor wants to have a look at the bolts. He thinks he might have a way to get them out.
As for the whirring noise, I added 10 gallons of AW46 (all I could get my hands on locally in a hurry) and the noise is reduced but not gone. I compared a GoPro video of me using this excavator last week and there was no such noise audible at all.
I added the fluid, which brought the level way up near the filler, and then exercised all of the tools, including the tracks, but the noise does not go away completely. It's even audible when I run the fuel lever at half position while doing nothing.
I bought a hand cranked pump that attaches to 55 gal drum and I just need to buy 1" hose to come off the pump and feed to the machine tank, and of course the 55 gal drum of hydraulic oil, and then I can flush the system and change the filter.
The whirring sound is concerning though. Never noticed that before last night's change of the forward stick pilot line. In all other respects, the hydraulics work normally. Just noisy now.
