I posted this problem here a while back but am not sure I am using this forum correctly so I will run it by again.
I have a PC300LC-6. I had trouble with the arm cylinder and had it rebuilt. ( the snubber came loose from the piston and beat things up pretty bad. some small pieces went down stream.) The arm still drifts both out and in. Any I ideas what to look at next? I tested the cylinder and believe it is OK. There was some damage to the quick return valve but I cleaned that up and the spool floats freely now. I swapped some suction safety valves around and nothing changed. (Note) When I shut the unit down with the arm full in or full out I can here fluid leaking buy in the main arm control valve area. Any more thoughts out there? Also does any one know where I could pick up some used or surplus parts for the control valve?
