G'day all,
I require a seal ring for the adjustable compensator valve in the auxillary valve segment. The seal is listed in the attached pic (item no.4) but no part number is supplied. I have talked to my local dealer with no luck in sourcing a part number.
I was wondering if anyone has a source for these solid square nylon type material seals. Or an alternative. I don't have the dimensions with me ATM but it would be approximately 10mm od and maybe 2mm section.
Yes I can get the whole valve as an assembly but it's pricey with a 2 week wait from overseas. I would like to confirm the missing ring is causing my issues before ordering the valve.
Machine is a late model PC120-6 s/no 63913
Cheers,
Sam
Cheers,
Sam
