I just found this thread that my brother in-law started to get help with my excavator. Thank you all for your input. It seems like a great group here.
I now have the excavator running without smoking but will not shut down again. Last time this happened I think that it was because one injector pump plunger was not aligned with the other two leaving a constant fuel flow. Without knowing everything that Jay tried when I was not around here is that basics of what I know.
- It was run low on fuel and sediment from the bottom of the tank got into the system. I had bought the unit late last summer and we only used it a couple of times without problem. I intended to do a full service on it before doing any heavy work but just did not get that far. Neither of us noticed that there was no fuel filter in the bowl and I have never owned equipment like this before and probably assumed that there was a filter inline somewhere but that was not the case.
- Jay had removed the injectors and fuel lines to clear them all as well as the tank to flush it out the best he could. I brought an ultrasonic cleaner home from work to thoroughly clean out the injectors being careful to keep all components with each injector.
- Jay installed a new fuel filter.
- Someone on this forum noticed that the first cylinder injector pump plunger was not aligned and I managed to get it all squared back up. Probably just lucky by aligning it in to the same position as the 2nd and 3rd cylinders.
- Ran fine to get it across the yard and then for an hour or two later in the week to did a short trench but then it started lagging real hard under load and blowing a lot of black smoke.
- Figured out that the injectors were not seated/sealed well and fuel was leaking past two injectors also allowing air in. I ordered a couple of seats and insulating protectors and changing them out so now we have great seals on the injectors.
- The 2nd injector was still leaking a tiny bit and I added two wraps of teflon tape around the seat and insulator. I am not sure if it will eventually melt but it gave us that seal that we needed.
- While replacing the injector seats and insulators I noticed that the 3rd injection pump valve holder was a little loose. I took it out and opened the front cover to make sure that it was still aligned with 1st and 2nd and reassembled it.
At this point we can start the machine and it will idle. If we increase the rpm it stays high even when we put the throttle back to idle. If we pull the fuel feed line at the injector pump it stalls out pretty fast so we installed a fuel shut off in that position but if we turn the fuel off there it continues to run on. It appears that the engine somehow is pulling fuel back through the return lines to keep running unless we stop the fuel feed and allow air into the system. Other than not shutting down it seems to be running pretty good with no smoke. Considering adding another fuel shut off to the return side and closing both when we need to power it down just so I can use it. Is this a bad idea? I have already lost a summer of projects because of this and really need to get a couple things done before winter.
How bad do you thin it is monkeyed up at this point? Is there something simple that we can look for or try?
