Is it possible if that spool is stuck that the arm can be weak and slow?What's that spool ?? BOOM, STICK, TRAVEL etc...???
ARM HALF FLOW VALVE = ARM THROTTLE VALVE
Sure! ARM performance will be slow if it's stuck.Is it possible if that spool is stuck that the arm can be weak and slow?
LACHAU makes it easy.Thanks,lot’s of circuits to trace!
Please!The pressure switches on the PPC manifold signal the computer for the auto decal mode. The electrical component in the photo is a pressure transducer. Komatsu at that time made a Tee tool that would plug in between the computer and the machine harness. It had a function that would display the pump pressures sent from those transducers.
