I got the thing apart and replaced the band brake pads. The ones in it were worn down to about .125 or less. Some of the brass rivets fell out also being the pads were so thin. Ordered some new pads from a company called Blumaq and the pads look pretty good. Had to countersink the holes on the new pads just a little more for the rivets though. New pads were about .375 thick. Riveted on the new pads, kind of a chore putting in all 128 brass rivets but I made a small c frame press tool to do it on the table and worked really good. Forgot to look at the clutch pistons, Hopefully Its good though being I was getting good pressure on the test ports. Measured the steering clutches and spacers and they were all in spec too, and looked good so I didn't have to do anything with them too. Only issue i have so far is that the book says to adjust the brakes the front bolt has to just touch the front piston which is done and then torque the rear adjuster to about 65 ft lbs. Then as the book says tighten the adjuster counter clockwise 1-5/6 turns. This is confusing, counter clockwise is looseining the adjuster as I look at it. I didn't think I could go another 1-5/6 turn in after tightening it to 65 ft lbs so I loosened it. I guess if it slips or drags ill just adjust it accordingly. I would assume one would want the brakes to slip right now with the machine sitting, not in gear, so it won't take off until revved up.
