John arthur Williams
I got a Komatsu d39 that I’m trying to find out how to smadjust the steering brakes
Thank you I will have to go give that a look and seeD39P-1 is the sane as a Dresser TD9-H. On the frame above the final drive it looks like a stud, but a small hex head on it and a large locknut. You may have to scrape dirt and or mud away to find it. On the so called stud there should be a few threads showing, if not the brakes are shot. To tighten the brakes, you need to loosen that lock nut and then you tighten the smaller hex head.
