Dennis M
I parked my D21 for about two weeks and when I came back to put it back to work it would not start, cranks over just fine but not a wisp of smoke from the exhaust. Obviously a lack of fuel to the engine so to make a long story short it is getting plenty of fuel out of the filter and makes it all the way to the injector pump inlet but that's it, I can open the lines coming out of the pump going to the injectors and get nothing not even a dribble. This dozer was running just fine when I last shut it down but now two weeks later when I attempted to start it I am getting plenty of fuel to the injector pump but ZERO fuel to the injectors. I suspect a failure of the shut-down/fuel cut-off in the pump maybe??? Any suggestions on what to do next?
I am fairly sure the actual pump itself should be OK but with the shut-down/fuel cut-off being an integral part of the pump body and actuated internally by the throttle lever (no electric shut-off solenoid or separate shut off lever) I am not sure how to even check this, of course at this point I am simply guessing at the problem. Any suggestions would be very much appreciated!
