Kobelcosk80msr2004
Hello guys!
I`ve buyed kobelco 2004 sk 80 msr 1e,(isuzu motor) and have some issues with the machine. Mechatrol control shows code error/fail E01 and E05. Have been trying to find out what that could be, but with no luck . Anyone have ideas what codes could mean?
Earlier guy who had machine have build throttle on wire,but stepper motor is sitting there- but not moving at all?
throttle rod is missing between pump and stepper motor, i have ordered new rod,but no use if stepper not moving at all.
Should machine go throw test on stepper motor before start upp,
Is code E01 and E05 because of stepper is not working? Have measured cables what go into the stepper and one two wired is 24V coming inn and other 4pin cable measured OHMS all pins are 2,85-its same even if moving throttle knob inside.
Should measurements change on 4 pin cable if i`m moving throttle knob or is fault only in stepper motor?
Appreciate any help.
