Kobelco sk60 acera
firetransport
N. Cal
Saw an add for a kobelco sk60 locally, considering buying this machine as an entry level small ex. Any advice or problems with this machine? Thanks
uffex
Lincoln UK
Admin
Good day
Recommend you take a good look round could save you some unpleasant surprise, see attached.
Kind regards
Uffex
  • Visual inspection form 1.pdf
  • Visual inspection.pdf
firetransport
N. Cal
SK60 Acera, I believe those are grey market machines which could present a problem for getting some parts. Something you need to check into.
Thanks I was wondering about that, the machine is blue not the yellow/grey if that makes a difference.
TVA
USA
Grey market means that machine was not imported to US through official channels and do not conform to US standards. Finding parts for these machines can be difficult.
firetransport
N. Cal
Right, however I thought the import brand machines paint varried depending upon if it’s a grey market machine vs non grey market? At least that’s what I’ve heard, was wondering if someone could confirm this.
Kobelco ireland
Ireland
Mechanic
Do you know what year the machine is, older models can be difficult to get some parts for regardless for it being grey market or not, newer models you should have no problem getting parts for
firetransport
N. Cal
Ended up going a different route. I bought a case 855d with a 4in1 and extendahoe. It’s for a small demolition/cleanup job so it should work out well.
