tractor geek
Hi all. New here so hopefully i get this rite,
I have a Kobelco sk135 fairly early model, Problem is (to start with) the machine can start up and work fine until switched off, restart then sometimes the engine will be under slight load, Which then at high revs and dead ending a circuit more or less stalls the engine, Stop engine wait for the ecu to totally shut down then restart would work fine again untill the next time you switch off, Does not do it everytime but intermintant fault to start with.
Now its doing the fault more and more,
No error codes, Swapped controller with another machine and fault never showed on it,
Would anyone know of the voltage to be measuring at the pump proportional solenoids?
Any help with this would be appreciated
Thank you
Thank you
