we have a 1998 sk115 dz that had a bad oil leak on the right pilot control. I removed the valve and had it rebuilt at a hydraulic shop. When I reinstalled the valve all functions of the valve were slow.
After some use now the only slow function is bucket curl. I tried to bleed out any air by cracking the hoses at the main valve body. Same result. I tried swapping the relief valves for bucket open and curl with no luck. The bucket still runs slow when curling. Normal speed when opening. Any suggestions would be great. Thanks
