John C.
Got a call from an old customer last week about his dump truck. It seems he rented the truck for a day or two and the lever puller slammed the shift lever hard enough to knock it out of the quadrant rails. The stick was just flopping around when I got there. I pulled the shift tower and shifted the socket on top so the transmission was back in neutral and then reinstalled the lever. I thought I had it made but when I tried it out and went over to check forth and fifth I noticed the lever could keep going until the ball went out of the socket again. I pulled the lever back out and set all back together right again and noticed that when I moved over to the forth and fifth position again I heard the high low spit air. I haven't worked on truck trannies since the nineties so don't know where to turn next. I didn't get the numbers off the box today but should be back up there tomorrow to look again. The pattern was different to me in that fourth gear was across from second while fifth was where forth would normally be. Year and miles on this monster are lost in antiquity. Speedo hasn't worked since they got the truck years ago.
Any clues or suggestions would sure be appreciated.
