K 12 insley
td25c
indiana
Keep up the good work Ryan ! :cool:
Have a Hendrix bucket for the Insley just like the one on your Linkbelt .
Tugger2
British Columbia
My Insley isnt so shiny anymore,but its still hanging in there.
ryanmueller
oregon
How is the power terrain laid out on those insleys? Do the have torque converters or transmissions? Can you run them down through the gears or does the boom have a sprag clutch like my link belt.
td25c
indiana
Boom has power down on mine . No torque convertor . All old school mechanical . Winch mainlines don't , all " feel" though the brake peddle when lowering a load . Ya get used to it after a few sets .:)
ryanmueller
oregon
can you disengage the main clutch and run down through the gears? Or does it boom up when you do that
td25c
indiana
No , can not run the main line's back though the gears due to the way the mechanical boosters work . It's all on the brake peddle when lowering a load on the main lines .
ryanmueller
oregon
My link belt is that way and my bantam is too but there is a leaver that disengages the boom shaft that allows you to run it through the gears but if you forget to re engage it and go to boom up or down it will free wheel down really fast and I'm sure you can guess how I found that out
Tugger2
British Columbia
My Insley is free fall on the boom, Lever under the seat. The 2 levers with the ratchet handles steer it. I havnt run it for so long its a head scratcher at first. and yes those are two 10B s and a 15 b also have a 22B and a 25B in my yard at work. Also the full Bucyrus sand box set,just need a 30B and ive got all the small crawlers
ryanmueller
oregon
IMG_2899.JPG This 35 ton p&h I've been running doesn't have power down so I've been getting good at just using the brakes. I've found it's a lot easier to pull back the clutch leaver just a little to provide a little drag to help slow things down. It also helps to put your finger right on the drum to feel slight rotation for precision work IMG_2942.JPG
Tugger2
British Columbia
Nothing like digging swing clearance with your counterweight.Pile driving is interesting challenging work. Just found some old pictures, heres my Insley in the mid 80 s when i first got it .I just had to have a crane so i took the backhoe off and bushwacked an old crane boom on to it. Now if i get time im going to put the back hoe on to it again.img864.jpg
alskdjfhg
Houston TX
View attachment 179136 This 35 ton p&h I've been running doesn't have power down so I've been getting good at just using the brakes. I've found it's a lot easier to pull back the clutch leaver just a little to provide a little drag to help slow things down. It also helps to put your finger right on the drum to feel slight rotation for precision work View attachment 179135
That looks familiar, I've got a 40ton P&H of the same vintage.
ryanmueller
oregon
Nothing like digging swing clearance with your counterweight.Pile driving is interesting challenging work. Just found some old pictures, heres my Insley in the mid 80 s when i first got it .I just had to have a crane so i took the backhoe off and bushwacked an old crane boom on to it. Now if i get time im going to put the back hoe on to it again.View attachment 179192
Awesome picture. I've always wanted to run a backhoe and a shovel. That Lima 34 I work on has a shovel front but it's missing the sprocket that goes on the drum for the crowd. The previous owner scrapped it and was about to scrap the shovel front with it
