Don't know if this picture will help. The cable that goes to the ball, should be on the middle one of the top sheaves (the one on the right in the picture), then straight down to the forward rooster sheave. Instead they have it on the left, and angled over to the front sheave. The first line to the block should be on the left, straight down into the lower sheave on the left then into the block. Instead they have it on the center, then angled way over to the right side of the bottom boom sheave.
Then they've got the block first cable on the far right sheave, then on the middle left sheave. That makes the block unevenly loaded. It will hang crooked and eat on the sheaves of it and the cable- but the block has steel sheaves, and it ends up being quite a ways away from the boom tip, it isn't as big a deal, the top of the boom reaving is a accident waiting to happen.
The danger with the mess on the boom tip, top to bottom cross running, those are nylon sheaves, not steel. If they get angle loaded like that with any kind of weight, it will pop the outer edges of the sheaves off, and probably totally crack the sheaves. Then you have a load in the air, with nylon pieces falling out of the boom tip, and you end up getting the cable all ruined, running in the cracks or dead sliding on the broken sheaves, if you can even get the load to the ground. You can't side load cable at all on nylon sheaves. The old steel style sheaves you can kind of get away with doing a little tugging around, but not a nylon.
The operators manual always shows a drawing of how to rig the boom head for every possible set up. On a new rig, the dealer should have someone that knows what their doing go along and set it up. Its probably a $750,000 machine, you think they would do that at least. But a lot of the dealers don't have anyone that's actually a crane guy, and expect the customer to know what he's doing. Some of the buyers for these are a oilfield moving company sick of paying someone else, so just buy their own, and really don't know what they are doing either.
I hate to see people out of their depth, and putting other people at risk.
