Just some work pics
crane operator
sw missouri
New generator. 17,000lbs. Was told I could set right beside it, so I took the 40 ton. Jobsite trip= 45' radius= making one of my guys go get the 90ton to set it.
Bought some new chains and binders, I don't know where all the chains and binders go, but they seem to grow legs and walk away. Also in the corner you can see my junkyard purchases of a hyd. pump and PTO box. Setting up pto on the mack titan.
Trusses and trusses in the trees.
IMG_20241010_083514553.jpgIMG_20241010_165906655_HDR.jpgIMG_20241011_094815497.jpgIMG_20241008_084259333_HDR.jpg
micoasters
michigan
I can't find any pics. of the crane but it must have been fun putting the spinning roller coaster in at West Edmonton Mall. The floor was reinforced with tele-posts so they could bring in a 30 ton P&H crane in to install the pieces that were lowered through a hole in the roof with a huge crane ( I think a Liebherr 100ton+). The older (70's) P&H had the best profile and chart for working in the extremely tight confines. All the work was done at night because the rest of the amusement park was in operation during the day. Only a couple times was opening at 10 am delayed. The total weight of everything was 320 tons and it weaved around the other roller coasters and rides. During the day they put a barrier around the crane with a spec. sheet like it was a new attraction.
Galaxy Orbiter - Galaxyland, West Edmonton Mall (HD) - YouTube
bit late, but a photo of a crane inside the mall. this time for the scrapping of mind bender
micoasters
michigan
Tree job with the Mack and the fixed basket. They dropped the material straight down, then we took the basket off and picked the pieces out from the inside of the roller coaster track and set them on the outside.
View attachment 188379 View attachment 188380 View attachment 188381 View attachment 188382
That RT crane is a little smaller than the 30 ton P&H truck crane that installed the spinning coaster. I'm sure they reinforced the floor from underneath with jack stands in a similar way. I'm curious how much the dismantling cost.
A little bit further right of your pic. is the dented H beam support marked RIP for when a rider was killed and others seriously injured when the cars came off the track. A couple years ago there were pics. in the paper of where my former boss, who was an ironworker on the Mindbender, wrote a love note to his wife and kids. I think a pic. of the RIP on the dent would have been more interesting. I think the owners should have been forced into bankruptcy. Only a bunch of absolute morons wouldn't think to translate the maintenance manual from German to English!! Unbelievable is an understatement!!!
micoasters
michigan
it was translated I believe, but was translated poorly, same thing happened over 40 years later in mexico. on a clone of the ride called "quimera". this video explains it quite well.
crane operator
sw missouri
If you cant find on local i have one thats headed to for junk. Yours for the taking.
Thanks Tyler, we got one picked up from our engine parts guy on Friday. I appreciate the offer.
It uses a gasket where the pan meets it, but there is no gasket available for where it bolts to the block. I think we are just going to permatex gasket maker on it.
Tyler d4c
Salix Pa
If in not misstaken loctite 2892 is whats called for. Permatex probably has a cross
crane operator
sw missouri
Spicer 4 speed has a bad shift knob and needed some seals in the rebuilt gearbox.
No availability from spicer / tremec on the knob seals. Well, actually available just not for 90-120 days.
Kind of stared at the knob, and its the same knob the mack 12 speeds, just different labels. Thought maybe the mack man would be able to save us.
mack dealer parts guy said "we don't really deal with any manual transmissions anymore"....
Fleet pride man came through with some extra part #'s, and I actually found a reseal kit from weller's. So that's the solution for the air shifter.
This is what the old mack one's look like, and its the same as the spicer. IMG_20241112_165806926.jpgIMG_20241112_165929892_HDR.jpg
Tags
Connecticut
It’s great that a lot of us (especially you) have become really good at locating parts because more and more places are saying things like…
The fact that they say that makes me laugh, they may not but a lot of people do….
crane operator
sw missouri
In a lot of ways, the Internet has made it much easier to locate parts, because there's a much wider area, that you can search.
But somehow you still need to come up with a part number. And unfortunately when companies change hands, a lot of times the old numbering system goes out the window, and your looking for updated/ superceded numbers. That's when it gets fun.
