Just some work pics
Cheap "old" Geezer
With a trailer on ‘as a Test Drive’ the 46k right bag under mine I noticed nearly no sway. Had a load of live trees my ex boss ‘allowed’ me to move from tree farm to yard, all rolling two lane :rolleyes:
crane operator
sw missouri
Keep informed, has my interest how that works.
Ah, I believe it works through the miracles of can bus. Which is the equivalent of magic to me. I'm not sure how you send different information both directions through wires,
I'm of the school of : #1 I have voltage, or #2 I don't have voltage, and I can troubleshoot from there. But we'll get it sorted eventually.
Cheap "old" Geezer
Most cars, Harleys after 2013 have canbus, multiple signals same wire differing frequencies or some form of voodoo so they go to their respective points not affecting others.
Black Magic and Voodoo. Modern over used excess dependence electronics.
crane operator
sw missouri
What happens if you disconnect all the antilock sensors?
I don't know.
Late yesterday they found one of the ABS wheel sensors badly corroded and possibly not working correctly.
Cleaned sensor and connection up, triple checked all the other connections, and bumped up the air pressure in the governor (air pressure has always been a little low- and book says pressure is critical for transmission shifts). The test drive today, everything worked correctly, no error codes, no issues.
Current theory: ABS sensor bad, ABS pulls away throttle, throttle gets jumpy when pulled away, so that threw the error code on the transmission. When we thought the transmission wasn't shifting, it actually was shifting, and the ABS module pulls the lower throttle away, so that the operator thinks the transmission isn't working correctly. Maybe.
I don't know.
Be prepared to change out all ABS cables and sensors, cleaning the connections only works for
short term, once those corrode tough to clean. Be glad it doesn't have ABS traction control, or
does it.
crane operator
sw missouri
does it.
Not sure, to be honest about it. I know its ABS but don't know if its also traction control.
That's not great news about changing all the cables. They said all the other connections were great on the abs, just the one looked bad.
crane operator
sw missouri
Got prices for adding timbren rubbers to the AG100 today, $1,200 per axle.
Concerned the timbrens may affect off road travel articulation of suspension.
crane operator
sw missouri
i'd want to see the other side.
Its just as bad. I ran a grove that had the rear steer axles for a while, and it was nothing but trouble. I know of another one that the rear steer was all disconnected.
I went through the pictures of this crane on the auction site, and they have all the hyd. lines to it disconnected, and its obviously all jacked up. Most times, they just get the axles both pointed straight ahead and lock them in place, but they evidently just sent this crane to ritchie bros instead.
crane operator
sw missouri
They are pretty rare in the truck cranes. Most guys mess them up from not reading the book. They will only handle around 46,000lbs, but you get way over that weight, if you have all the counterweights hanging on the upper rear with the boom in the rest. The book wants you to leave some on the deck and take some off.
Invariably someone leaves the counterweight all hang and then tries to go through a mudhole and steer the rears. Then the steering linkages get bent or broken.
