So on the screen. Top right and down- I've got the computer set for 3 parts of line, I can handle 6,300lbs. I have 2,300lbs on the hook at the time of the picture. I'm at 108' radius, 41.1 degrees boom angle.
The A! means my boom sections are locked in the automatic extension I've selected, I've got 147' of boom extended, with each section locked at 92 percent. I'm 98' off the ground with the boom tip, and I have the alarm silenced (horn with the x through it).
At top left:
The L106 1400 0015 is the configuration set up (92 percent all sections, on full outriggers, with 35,500 counterweight- its all selected in a different screen).
I'm at around 30-40% cap per the sliding bar, and the 748 is the RPM's of the engine- it will only turn 1350 or so max RPM's running the crane.
The #2 winch is the aux (rear) winch and its showing 26.5' of cable extended (its actually stowed in this picture but I haven't zeroed the counter in a while) #1 winch is showing 39.6' of cable out. I usually don't zero these, I just watch them if I want to see winch movement- there's little arrows up and down when the winch is moving.
And the liebherr black and grey screens are really poor in sunlight. There's so much glare you can't hardly read them. I actually use my penlight all the time to read it. They are great in cloudy or low light- night work. I'm sure it looked great in the indoor lab when they bought them. The new screens are color- white background with blue numbers and such and much easier to read in sunlight.
