just bought a case 95xt have questions
Discussion in 'Skid Steers' started by oldrusty, Dec 1, 2018.
  1. oldrusty
    oldrusty Active Member
    Feb 6, 2017
    26
    Oklahoma
    i just bought a 2000 year 95xt case with ride control/two speed/hydraulic attach/high flow. does anyone have a photo of diagram what the buttons on the sticks and other controls all do? also any advice for anything i need to know or be careful of on this machine?
  2. Ronnestrand
    Ronnestrand Member
    Apr 16, 2017
    19
    Sweden
    There is pictures to the left and to the right that shows what you have. I think I got aux hyd, p-brake, two speed on the left. Just horn on the right
  3. Ronnestrand
    Ronnestrand Member
    Apr 16, 2017
    19
    Sweden
    The only thing I know I to check the tension on the chains
  4. franklinute
    franklinute Well-Known Member
    Dec 1, 2010
    94
    Winchester, TN
    I have a 90XT of the same year. I suggest getting a few extra relays to carry with you. These machines have trouble
    with the parking brake coming on and not releasing. Check the condition of the fuse block. It can get filthy. The safety
    switches on my seat bar and cab have been replaced or bypassed. Be sure the bearings in the wheel hub assemblies
    are packed with grease. The manual says to repack the bearings every 1000 hrs. The manuf upgraded the seal for the
    hub assembly. Be sure the oil in the chaincases is clean and not watery.
  5. oldrusty
    Feb 6, 2017
    26
    Oklahoma
    Thanks
    are the relays a common auto parts type or are they a case only relay? do you know the part number? do you have to remove the hub from the machine to repack the bearings? or is there a zerk? the machine has just over 200 hours on it and has been kept inside always when not used. it was only used to run a tree spade and i think that is the reason it has so many buttons on the joystick. how do i bypas the lapbar???
  6. joestewart
    joestewart Well-Known Member
    Oct 15, 2009
    194
    Lafayette, LA
  7. oldrusty
    Feb 6, 2017
    26
    Oklahoma
    Thank You Very Much.
  8. 62oliver
    62oliver Well-Known Member
    Nov 25, 2016
    97
    NWO
    Hey, thanks joestewart !!!!! Much appreciated !!!
  9. franklinute
    Dec 1, 2010
    94
    Winchester, TN
    I have used relays from local parts store with no issues. The hub assembley does have to be removed and
    the shaft pressed out to access the bearings. The last time I had the hub assemblies off I drilled and tapped
    two holes in each assembly. Now I run gear oil in the hubs. I use my 90XT to run tree spades with, interesting.
    I have a dutchman control grip mounted on my righthand lever. It has 9 functions. The lapbar has a button
    switch approx where the lapbar is bolted to the cab. You can run a jumper wire to bypass this safety switch.
  10. oldrusty
    Feb 6, 2017
    26
    Oklahoma
    yes as it turns out the right hand joystick control on mine is for Dutchman accessories. my ride control isn't working so i think maybe it is disconnected in the joystick.
