phil314
So I've had an intermittent starting issue with my 1845c for a while. At first is was just an occasional click and no crank, but as time passed, it became more frequent. I read about people adding external solenoids and several possible causes. It eventually reached the point where it was more clicking than cranking and starting. Something had to be done.
So instead of adding an external relay. I decided to rebuild the one on the starter. Turns out they use the same Denso starters as 89-06 dodge trucks. So I got a kit with the big contacts for a dodge truck.
https://www.genosgarage.com/product/lb-r90ss/engine-rebuild-kits-3
Fit perfect, but unfortunately it didn't fix my problem. But I figure I'd pass it along in case it helps someone else.
So the next thing I decided to try was the ignition switch itself. I was a bit skeptical of this, but I couldn't find anything else that seemed wrong. And this was cheap and easy. 2 of my favorite things. Well, it was night and day. It would crank and start every single time with the new switch. Old one must have just been worn out inside. I was a bit shocked, but also very happy to have a reliable machine again.
A few months pass and we get to today. I turn the key. I get a 1/2 a crank and nothing. I've noticed that the machine has been turning over a bit slow lately. But I doesn't 'click' in my head at the time. Not until today. Maybe the battery is getting old. Lets see, I put the last one in when? Dang I can't even remember. That probably means it's time for a new one. So I pull the old one out and the sticker on it says - 11/03. DOH! Yeah, maybe a new battery will help. Toss in a new battery and she spins like a top and fires right up.
